Code Review with crucible for BitBucket
Malik
March 14, 2013
answers.atlassian.com is quickly becoming the biggest online meeting point for Atlassian users. This is why I thought I would share with you some of the most common questions we receive directly at Atlassian Support and could be of interest for the whole Atlassian Community; For example:
-> How to best use Crucible when code is hosted on BitBucket?
3 votes
Malik
March 14, 2013
BitBucket offers in-line commenting for Pull Requests and commits. In addition to this, Crucible will also work with BitBucket to enable the most complete Code Review experience.
Install Crucible on-premise and hook it up to BitBucket. Now if on-premise isn't a favorable solution, an alternative is to have crucible installed on a virtual machine in the cloud (something like an EC2 image). You then have the option to create this virtual machine yourself, or you can use the one pre-configured by Atlassian for that matter.
Gustavo Hexsel
November 19, 2015
link is dead. Is there support to approve a pull request from Crucible?
Seth Krauss
January 14, 2016
Second. Interested in knowing the reverse too... can I generate a review from a pull request?
mcfoggy May 24, 2016
Then third, can we do both?
The public docs from both crucible & Bitbucket server do not give such info.
Mohammed Davoodi
August 29, 2016
Our organization has written a plugin to offer Crucible review integration into Bitbucket. You can check it out here. It allows you to automatically create Crucible reviews when creating pull requests, while also blocking Pull Request merges until the Crucible review is approved.
Aram Melkoumov
January 17, 2017
Hi @Mohammed Davoodi, your solution only work with Bitbucket Server, do you have one with Bitbucket Cloud support?
Mohammed Davoodi
January 17, 2017
@Aram Melkoumov not currently at this time. We're waiting for paid add-on's to get introduced into Bitbucket Cloud before we devote resources into making a cloud version.
Mohammed Davoodi
February 2, 2017
Our organization has written a plugin, Crucible Review Hook for Bitbucket to offer Crucible review integration into Bitbucket. You can check it out here. It allows you to automatically create Crucible reviews when creating pull requests, while also blocking Pull Request merges until the Crucible review is approved.
Marlene Cote July 11, 2018
any update on the availability with cloud?
and the cost?
Like # people like this
Reneesh Kottakkalathil
April 29, 2019
