Could not read from remote repository
Algotech June 12, 2019
Hello I followed this exactly -> "Setting Up SSH in Windows"
https://confluence.atlassian.com/bitbucket/set-up-an-ssh-key-728138079.html#SetupanSSHkey-ssh2
All steps checked out and even got success via -> ssh -T git@bitbucket.org
so after:
git remote add origin git@bitbucket.org:algotechllc/app_backend.git
I try:
git push origin master
Returns:
Unauthorized
fatal: Could not read from remote repository.
Please make sure you have the correct access rights and the repository exists.
10 votes
jredmond
June 13, 2019
You've added the public key to the repository as an access key. You need to remove it from the repo and add it to your account.
Algotech June 13, 2019
Thank you for your response, that worked perfectly!
Fantastic! Thank you very much!
giovanni_nsele
June 23, 2019
Thanks Jim, it was very helpful for me too. :)
seriiserii825 August 6, 2019
Thanks, you are so good.
But i don't understand, why bitbucket give a option to add shh-key to repo?
jredmond
August 6, 2019
It's for CI/CD systems - using those keys, they can pull updates without occupying a user license.
yairosv
October 10, 2019
Thanks a lot, it worked for me
ken.w.colvin
Manuel Malagon
This worked.
So, what are the individual repository "Access Keys" for?
Ernesto Orellana
July 23, 2021
Gracias funciona perfectamente, tuve el mismo problema cuando quise pushear.
llanero7
October 13, 2021
I spent hours searching for an answer to this creating keys in different ways. Thanks for this contribution.
Go to https://bitbucket.org/account/settings/ssh-keys/ and add your key there.
Hvesiksasha
January 24, 2022
Thanks! It works =)
zorrosweb
August 13, 2024
Yes. Your suggestion works smoothly. I have deleted the access key on my repo.
