I am getting the 'SSL certificate problem: certificate has expired' while pushing the changes in git using sourcetree.
Please help
For me, the problem was related to Sectigo expiring one of their root certificates. This means that any client/program that uses the old root certificate when attempting to verify SSL certs will throw a "certificate not valid" error.
If this is what you are encountering, you can fix this by re-installing / upgrading git. This will install the latest root certificates at the same time.
I found this worked on my local machine.
On a remote server that had the same issue, I had to upgrade git, and then re-install the ca-certificates on the server itself with:
sudo apt-get install --reinstall ca-certificates
sudo mkdir /usr/local/share/ca-certificates/cacert.org
sudo wget -P /usr/local/share/ca-certificates/cacert.org http://www.cacert.org/certs/root.crt http://www.cacert.org/certs/class3.crt
sudo update-ca-certificates
git config --global http.sslCAinfo /etc/ssl/certs/ca-certificates.crt
Then I still had problems and realized git was looking at the wrong path and had to correct it with the following:
More importantly, I realized that the actual root cause is the SSL certificate on my domain name that I am using for my Bitbucket Server.
The chain certificate had to be updated by removing the expired root certificate.
There is a good page with tools that can help you update your own certificates on your domains:
Updating Git to a newer version installs a new CA chain certificate which is used by Git. That solves the issue.
This fixed it for one of my users that had an issue
I have just set the following variable "http.sslVerify" to false and it worked. Just remember to set change it back later.
For a single repo
git config http.sslVerify false
For all repo
git config --global http.sslVerify false
This is not a good long term solution because you are basically choosing to use no encryption when pushing/pulling your code from Bitbucket Server. This means you are vulnerable to man-in-the-middle attacks.
All of this appears related to this: https://support.sectigo.com/articles/Knowledge/Sectigo-AddTrust-External-CA-Root-Expiring-May-30-2020
Has anyone found a fix? The only thing that has changed on my server is there was an Ubuntu kernel update.
Same here, trying to push changes and msg "SSL certificate problem: certificate has expired" appears.
Yes. I am having this problem. In bamboo also.
