×When I try to login in bitbucket, after entering my (correct) username and password, I am asked to authenticate with a hardware key or a passkey.
I have neither attached to my account.
I tried adding them and removing a time-based MFA and a passkey, nothing helps.
I can only login with my (few remaining) recovery codes. Please advise.
Hi @ObiJan and welcome to the community.
Can you please confirm if you are logging in to Bitbucket Cloud (https://bitbucket.org/)? I see that your question has the tag 'bitbucket-cloud', but you mention log in with username and password, while log in to Bitbucket Cloud from browser is done with an email address (instead of a username).
If this is indeed Bitbucket Cloud, there are two places to check for security keys and disable 2FA.
Atlassian account 2FA
I am quoting the instructions from our documentation on how to remove a security key, if you see it listed there:
Manage your security keys
You can add multiple security keys, delete keys and rename keys.
From the Two-step verification page, enter your Account password and select Unlock settings
You won't see this option if you recently entered your password.
Manage your security keys under Manage security keys
Cick on Register new key to add a new key
Click on Delete to delete a key
Click on the key name to Rename a key
There should also be a link at the bottom of the page (in https://id.atlassian.com/manage-profile/security/two-step-verification) to disable Atlassian account two-step verification.
Bitbucket Cloud 2FA
It can be managed from the following page:
I am attaching a sample screenshot of this page:
If you see a security key listed, like in the screenshot above, please click the x icon in the row with this key to remove it.
You can also click the link Disable two-step verification (top right corner in the screenshot) to disable Bitbucket 2FA.
After you check all the above, please open an Incognito / Private window of your browser and try to log in again to see if you get the same prompts or not.
Theodora
Just to be clear:
- I do not have any 2 factor enabled on my account, so I can't delete any. As said above, I did try to add a factor and then remove it, result was the same
- Ironnically, when I login now, after logging in with password, I get a required email validation, sometimes I get promted to turn on 2FA (which I decline) before being asked to press the security key.
Feel free to look at my account to confirm that I don't have any key assigned to it.
Hi @ObiJan,
Can you please confirm if the affected Bitbucket Cloud account is the one with the same email address as your community account that you used to post this question?
If so, our system shows:
I don't have visibility on the security keys that are added to an account.
Please let me know the following:
1. If the affected account is the one with the same email address as your community account.
2. Please provide a screenshot of the following page (make sure that your name, which shows near the left right corner, is not included in the screenshot):
3. Do you still get asked to press a security key if you log in to https://bitbucket.org/ with email address and password from an Incognito / Private window of your browser?
Theodora
That's good to hear, thank you for the update! Please feel free to reach out if you ever need anything else.
Theodora
