We used to be able to embed a Jira issue collector script in the Announcement Banner for Bitbucket (Add-On by Sweet Bananas) however, that add-on has become monetized and we are not playing along. The Built-in announcement banner displays the script. What other options are available?
Create a simple Bitbucket server plugin and add the issue collector script as a web-panel in atlassian-plugin.xml like so
<atlassian-plugin ... plugins-version="2">
<web-panel location="bitbucket.notification.banner.header" key="kevins.test">
<context>atl.general</context>
<resource name="view" type="static"><![CDATA[<script ......></script>]]></resource>
</web-panel>
</atlassian-plugin>
The issue collector tab is shown on any bitbucket page.
Tip: place the collector tab as vertical, horizontal version may be hidden by the BB page header
Let me know if you run into any trouble
Ulrich,
I am a newbie on the server CLI, so you lost me at "Create a simple Bitbucket server plugin and add the issue collector script as a web-panel in atlassian-plugin.xml like so..."
My understanding is then that the issue collector script gets put somewhere on the server after I run atlas-create-bitbucket-plugin on the server. I'll need to read much deeper to determine exactly which directory I would run that and the Issue Collector script generated by Jira.
(Sorry for the very late response: We did a lift & shift of our servers from our on-prem data center to AWS Cloud Services in September and we've been slightly busy) (:)
Your script JSM content goes directly into the
placeholder in atlassian-plugin.xml
No extra files needed.
