How do I connect to bitbucket remote repo and get a file through c# application?
Divya Dharani August 10, 2018
I don't want to clone the repository locally. I want to access a remote file residing in the remote repository through a Windows Form application. How can this be done?
Ana Retamal
August 10, 2018
Hi Divya, welcome to the Community!
You'll need to give us more context so we can understand what you're trying to achieve:
  1. Are you using Bitbucket Cloud or Server?
  2. Why don't you want to clone it locally?
  3. What is the purpose of accessing it through a Windows Form application?
Cheers!
Ana
Divya Dharani August 11, 2018
1. Bitbucket Cloud
2. Because I don't want to retrieve the entire branch for accessing a single file
3. I want to get the contents of a file from a remote branch and do some comparison job with DB contents through a Windows form application. Basically, my intention is to create a comparison tool which will compare a remote file's specific contents with DB. How can I achieve this?
