How to publish docker multi-arch images with Pipeline runtime v3
Antoine June 26, 2025
I was very excited about the Pipeline runtime v3 release and wanted to use it for publishing multi-arch docker images using it.
I followed your documentation, to build images for platforms linux/amd64 and linux/arm64. They are built correctly. However, I'm not able to list them with `docker image ls --tree` nor publishing them in a separate step.
I followed your instructions by first creating an image with docker-cli, compose and buildx preinstalled and then defining a pipeline custom trigger to build the docker multi-arch image as described in 'Multi -arch Build' section.
The build produces this warning message:
WARNING: No output specified with docker-container driver. Build result will only remain in the build cache. To push result image into registry use --push or to load image into docker use --load
Is there a way with bitbucket pipeline runtime v3 to list and publish multi-arch docker images after the build step?
Thank you very much for your help!
Mark C
June 29, 2025
Hi @Antoine
Welcome to the community.
Could you please share your YAML config for us to check? Please mask any sensitive information before sharing it
Mark C
Antoine June 30, 2025
Hello @Mark C
Thank you for your support.
I used the config given in the documentation
options:
  runtime:
    cloud:
      version: "3"
pipelines:
  custom:
    multi-arch-build:
      - step:
          image: "<my-image-with-docker-cli-and-buildx>"
          services:
            - docker
          script
            - docker buildx create --name multiarch-builder --driver docker-container --use
            - docker buildx inspect --bootstrap
            - docker run --rm --privileged tonistiigi/binfmt --install all
            - docker buildx build -t test:local --platform=linux/amd64,linux/arm64 .
- docker image ls --tree # won't return any image
- docker image push test:local # fails
I added some comments with problematic steps
Antoine July 8, 2025
Hello @Mark C
Were you able to look into the issue?
Thank you for your help!
Best regards,
Antoine
Ben
July 8, 2025
Hi @Antoine
Apologies for the delay - I have taken a look into this in Marks absence.
When using docker buildx build with the docker-container driver, the built image is not automatically loaded into the local Docker image store. Instead, it stays in the BuildKit cache unless you specify an output option - hence why you receive the error:
  • --push to push the image directly to a registry.
  • --load to load the image into the local Docker daemon (only works for single-platform builds).
Docker image ls shows nothing as the image is not available locally because it was never loaded (--load) or pushed (--push). That's why docker image ls --tree returns nothing, and docker image push test:local fails—there's no local image to push
Please modify your YAML config to the following and let me know if it's successful:
script:
   - docker login -u $DOCKER_USER -p $DOCKER_PASS <your-registry>
   - docker buildx build -t <your-registry>/<your-image>:<tag> --platform=linux/amd64,linux/arm64 --push .
If you're still encountering issues - please raise a ticket directly with our support team using your paid workspace URL to ensure you receive timely responses according to our SLA. Raising a formal ticket will allow us to gain access to your workspace to check your YAML config/build logs in detail:
If you have issues raising a ticket - please let me know your timezone and I will raise one on your behalf with the relevant team in your region.
Cheers!
- Ben (Bitbucket Cloud Support)
Antoine July 9, 2025
Hello @Ben
Thanks a lot for your support and all the explanations!
Thing is we have internal tooling I would like to reuse for multi-arch builds. This imposes to push images in a separate step and not during the build step.
From what I understand from docker doc it would help having access to containerd which is able to store multi-arch images. Do you know if that's possible with the new pipeline runtime v3?
Thank you!
Antoine
Mark C
July 16, 2025
Hi @Antoine
Apologies for the late response here.
What you can do is to use --load flag in the buildx command if you'd like to access the built container within the same step.
Mark C
