Is it possible for Bitbucket pipeline to build a docker image from private ECR base image?
Shuo Hua
February 25, 2022
In our pipeline we would like to build a docker image that uses a base image from a private AWS ECR and then push the build image to our AWS ECR. However when doing that following the standard setup, we got following error:
docker build -t <image-name> .
Sending build context to Docker daemon 3.072kB
Step 1/6 : FROM <AWS-ECR>/<base-image>
Head FROM <AWS-ECR>/v2/<base-image>/manifests/latest: no basic auth credentials
Our pipeline setup is the following
custom:
    build_and_push_to_ecr:
        - step:
         service:
- docker
script:
- export AWS_REGION=<AWS-REGION>
- export AWS_ACCESS_KEY_ID=<AWS-ACCESS-KEY-ID_THEIRS>
- export AWS_SECRET_ACCESS_KEY=<AWS-SECRET-ACCESS-KEY_THEIRS>
- docker build -t <image-name> .
- pipe: atlassian/aws-ecr-push-image:1.4.2
variables:
AWS_ACCESS_KEY_ID: <AWS-ACCESS-KEY-ID_OURS>
AWS_SECRET_ACCESS_KEY: <AWS-SECRET-ACCESS-KEY_OURS>
AWS_DEFAULT_REGION: <AWS-REGION>
DEBUG: 'true'
IMAGE_NAME: <NAME>
TAGS: ${BITBUCKET_BRANCH}
The Dockerfile we want to build looks like
So is it possible for the docker service to build with a private base image or it must be public?
Ankit Gupta
Your docker is not logged in with the AWS ECR credentials. You need to add the below line to the script before `docker build`:
 aws ecr get-login-password --region $AWS_REGION | docker login --username AWS --password-stdin $AWS_ECR
Shuo Hua
February 28, 2022
Thanks!
That did the trick
rahulmr January 18, 2023
Could you please share which image you have taken and how do you implemented it? What is the value of $AWR_ECR and where you added this command? a sample bitucket-pipelines.yml could be a great resource to learn
stephenrichards May 4, 2023
@Ankit Gupta - How would this work if I am using OIDC?
