No single ai review generated for weeks
Thomas Kekeisen
We enabled the new code reviewer a few weeks ago but since then not a single comment was created. Is there any common issue we could have made? Anything more required than just "enabling" the feature?
Mark C
June 20, 2025
Hi @Thomas Kekeisen
Thank you for reaching out to the community.
Could you confirm if Rovo Dev Agents is activated in your workspace and the specific repository?
Mark C
Thomas Kekeisen
Mark C
June 25, 2025
Hi @Thomas Kekeisen
Thanks for the confirmation.
Could you check if the repository and PRs inside it is not hitting the limitations mentioned here? - https://rovodevagents-beta.atlassian.net/wiki/external/MmVjYmFiNzA1NjQ0NGZjODg5NTBhMGM3OTQyYTQ4MmY#Code-Reviewer-specifications
Mark C
Thomas Kekeisen
Hi Mark,
thank you. I can also confirm that none of the limitations are hit. Do you have any logs on your side?
Thomas
Syahrul
July 8, 2025
Hi Thomas,
To make sure you have all prerequisites enabled, can you confirm that you've done the following:
  1. Install Rovo Dev Agents on your site
  2. Connect Bitbucket to Jira
Once you confirm that this has been configured correctly, please wait around 10 minutes and then try to create a new pr.
Let us know how it goes.
Syahrul
Like Thomas Kekeisen likes this
Thomas Kekeisen
Hi Syahrul,
thank you. For now I can confirm that it started to work on very small PRs.
Thomas
Like Mark C likes this
Product Admin Site Admin
