×I have ability to access Bitbucket projects as well as repo links and i have enough privilege's to do so.. But when i tried to access the Watchers settings links under my profile its getting 401 permission denied issues even though i clicked watch Projects icon.. Not sure whats the reason of getting permission issues..
@Radha Kandimuthu - hi Radha! Can you confirm the exact version of Bitbucket you're using?
I've moved your question from the "Jira Service Management questions" to "Bitbucket questions" section of Atlassian Community, FYI!
@Radha Kandimuthu - I appreciate you marking my answer as accepted, but I didn't actually provide a correct answer to you (yet!).
I've un-accepted my own answer. 😊
Radha:
Appreciate any insight.
Bitbucket Data Centre Version 6.10
-> Im Accessing bitbucket from different pc with on perm hosted servers
@Radha Kandimuthu - hi Radha! To confirm, when you click "Watches", you're getting a 401 error? Can you attach a screenshot?
(Have the option of upgrading your Bitbucket version to the latest (7.10, as of right now), or to a later version? I don't think that would fix your issue, but it comes with user-facing improvements.)
