Pipeline stuck at running Bower
rzky
I got this error message about cannot run with sudo even though i didn't sudo anything. See my pipeline.yml below.
bower ESUDO         Cannot be run with sudo
bitbucket-pipelines.yml
image: node:6.9.4
pipelines:
  default:
    - step:
        caches:
          - node
        script:
          - npm install -g bower ember-cli@2.13
          - npm install && bower install
          - npm run deploy
wilsonmanzano
January 27, 2020
Did you find any solution?
Andrea Salicetti
April 21, 2020
Same problem here: any solution found?
wilsonmanzano
April 21, 2020
I'm not sure what was causing my error but I'm not using sudo for the pipeline
M Fahima Hanifa October 21, 2020
try add
--allow-root
like answered in https://serverfault.com/a/566925
