Problem setting up bitbucket with PGSQL
sharad mishra
April 4, 2019
I have been trying to setup my bitbucket server with postgresql but i am getting the following error. I have tried with different passwords but i am not able to get past this step. Pl help.
The configuration entered is not valid. A database connection could not be established. Please check your configuration and try again. com.atlassian.stash.internal.db.DefaultDatabaseManager.validateConfiguration(DefaultDatabaseManager.java:217) com.atlassian.stash.internal.db.DefaultDatabaseManager.prepareDatabase(DefaultDatabaseManager.java:183) com.atlassian.stash.internal.maintenance.SpringMaintenanceTaskFactory.setupTask(SpringMaintenanceTaskFactory.java:151) ... Failed to obtain JDBC Connection; nested exception is org.postgresql.util.PSQLException: FATAL: password authentication failed for user "*******" org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:81) com.atlassian.stash.internal.db.DefaultDatabaseValidator.validate(DefaultDatabaseValidator.java:44) com.atlassian.stash.internal.db.DefaultDatabaseManager.validateConfiguration(DefaultDatabaseManager.java:214) ... FATAL: password authentication failed for user "*******" org.postgresql.Driver$ConnectThread.getResult(Driver.java:405) org.postgresql.Driver.connect(Driver.java:263) java.sql.DriverManager.getConnection(DriverManager.java:664)
Yogesh Mude
April 4, 2019
HI @sharad mishra
Welcome to the community!
Please try to reset the database password and then try it once again.
ALTER USER <DB_NAME> WITH PASSWORD '<PWD>';
sharad mishra
April 4, 2019
Hi Yogesh. Should it not be <USER_NAME>; Anyway, I tried this but it didn't help.
Yogesh Mude
April 4, 2019
Sorry, it's not a Database name but its a role name using which you are accessing the database.
