Problem when cloning bitbucket repo: HTTP/2 stream 0 was not closed cleanly
Saeid Ghouli February 4, 2019
Dear friends,
Hello.
I have problem cloning any file to my computer... It just tells me:
Error: fatal: unable to access 'repo': HTTP/2 stream 0 was not closed cleanly: STREAM_CLOSED (err 5)
Btw, I am new to Bitbucket and Git and I do not know any technical thing about them.
Your help is so much appreciated.
4 votes
Elias Rahmani
September 29, 2019
Hi Saeid and all fellow developers from Iran who come down with this issue, If you are using SourceTree git GUI, you are able to add your proxy setting by checking it in this directory:
Tools>Options then network tab and check this option:
- Add proxy server configuration to git/mercurial.
And if you are on Linux, you need to set a DNS server for such purpose.
Best wishes
Anicka
January 22, 2022
Hi
thank you for your information. would you please tell me how can I fix this issue on Linux?
Ana Retamal
February 6, 2019
Hi Saeid, welcome to the Community
Error messages like "empty reply", "stream not closed cleanly", and "connection closed by remote host" suggest that something in the network between your system and Bitbucket is preventing traffic. Are you using a proxy of some kind?
Best regards,
Ana
Saeid Ghouli February 6, 2019
Hello Ana, thank you for your response!
Yes, since I live in Iran and cannot access Bitbucket with normal internet connection, I need to use VPN to do so. Can you please help me on how to connect to Bitbucket without problem?
Best Regards,
Saeid
Ana Retamal
February 6, 2019
Hi Saeid, in this case you'll need to contact your VPN provider to know what is causing this connection issue. Since they're causing the problem, they should be able to help you establish a good connection or provide a workaround.
Hope that helps!
Ana
Thank you Ana.
But I think the VPN providers would not take any responsibilities.
Thank you anyway, I would find a way myself.
