Same problem for me: https://bitbucket.org/muellerflorian/fish_quant
Over 200 spam issues since last friday.
I don't have the time to delete them one by one.
Mass deletion, and an option to disable anonymous issues would be greatly appreciated.
Hi @muellerflorian ,
Thanks for reaching out to the Community!
I've moved your post to a new question for easier tracking.
Our engineering team can help with either:
Please keep in mind that there is a possibility for false positives to be included in the flagging or removal. If you are concerned about irreversible loss, we would suggest requesting flagging, so that you can review the issues.
Before we proceed, please make your issue tracker private (Repository Settings > Issue Tracker > Private issue tracker) to prevent the creation of new spam issues. I will post an update here once our engineering team has mitigated the issue and when it's safe to make your issue tracker public again.
Afterward, please let us know whether you would like us to proceed with flagging issues as spam in your issue tracker or removing them :
Let me know in case you have any questions.
Thank you, @muellerflorian !
Patrik S
Dear Patrick,
first, thanks a lot for being so responsive.
second, no new spam issues are popping up since a 2 days! Thanks for that!
third, for removal. could you please delete issues 32-202
Thanks a lot!
Florian
Hi @muellerflorian
we have resolved the spam issues from issue ID 32 to 202. We hope this helps. Apologies for any inconvenience this may have caused you.
Suhas
There is an option in repository settings to disable anonymous issues. At least for me, this seems to have stopped the spam (fingers crossed), though other comments suggests it might not work for everyone.
For me, I can't even change the settings since it's not my repo, I only have contributor access, but I still get the emails. The only thing I can do is disable all notifications on my profile, which is not ideal.
