I have been google like crazy for the following error on Sierra for the last couple days with no luck. Any pointer will be much appreciated!
svn-migration-scripts: using version 0.1.56bbc7f
Git: using version 2.18.0
Subversion: using version 1.9.7
Can't locate SVN/Core.pm in @INC (you may need to install the SVN::Core module) (@INC contains: /usr/local/git/share/perl5 /Library/Perl/5.18/darwin-thread-multi-2level /Library/Perl/5.18 /Network/Library/Perl/5.18/darwin-thread-multi-2level /Network/Library/Perl/5.18 /Library/Perl/Updates/5.18.2 /System/Library/Perl/5.18/darwin-thread-multi-2level /System/Library/Perl/5.18 /System/Library/Perl/Extras/5.18/darwin-thread-multi-2level /System/Library/Perl/Extras/5.18 .) at /usr/local/git/share/perl5/Git/SVN/Utils.pm line 6.
BEGIN failed--compilation aborted at /usr/local/git/share/perl5/Git/SVN/Utils.pm line 6.
Compilation failed in require at /usr/local/git/share/perl5/Git/SVN.pm line 25.
BEGIN failed--compilation aborted at /usr/local/git/share/perl5/Git/SVN.pm line 32.
Compilation failed in require at /usr/local/git/libexec/git-core/git-svn line 22.
BEGIN failed--compilation aborted at /usr/local/git/libexec/git-core/git-svn line 22.
git-svn: ERROR: Unable to determine version.
Problem resolved. Instead of doing installing perl (cpan SVN::Core)
I made use of brew to install both git and svn on and was able to finish the prepare step
$ java -jar ~/svn-migration-scripts.jar verify
Git: using version 2.19.1
Subversion: using version 1.10.2
git-svn: using version 2.19.1
Hi John, can you give us some more information to help us troubleshoot this issue?
Best regards,
Ana
Ana, I was preparing my local Mac Sierra for the migration by following step written down here https://www.atlassian.com/git/tutorials/migrating-prepare
The specific command steps was executing from terminal was:
Any help will be appreciated!
