Welcome to the community.
You can indeed use the Pipes script to trigger a Pipelines build in the same repo by specifying a specific branch or tag.
When you mentioned triggering the same pipeline, are you referring to re-running a previously ran Pipelines build?
Mark C
Thanks @Mark C for your answer , we need to trigger the pipeline from one repository to another repository.
