is it possible to run a script before running a pipe?
yivi
May 27, 2019
I'm trying to build a pipeline to build and deploy to S3 one of our angular projects.
I can use the atlassian pipe for this (atlassian/aws-s3-deploy:0.2.4), but since I'm using the same build task for staging and production a specific configuration variable needs to be "injected" on artifact to be uploaded with different values to each environment.
The developer asked a file with the URL for the API backend to be inserted (to use the staging or prod API on build).
I thought of running another script step to generate the file (using a value from a deployment variable) on the distribution directory, but this doesn't seem to work:
image: node:10.15.1
definitions:
build:
- step: &build-generate
script:
- npm install
- npm run build:prod
artifacts:
- dist/**
deploy: &deploy-to-s3
- step:
deployment: staging
script:
- echo "var BASE_URL = \"$API_CORE_URL\";" > dist/site-admin/assets/config.js
- pipe: atlassian/aws-s3-deploy:0.2.4
variables:
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
AWS_DEFAULT_REGION: "eu-west-1"
S3_BUCKET: $OUR_AWS_BUCKET_NAME
LOCAL_PATH: "dist/site-admin"
ACL: "public-read"
CACHE_CONTROL: 'max-age=3600'
DELETE_FLAG: 'true'
EXTRA_ARGS: '--follow-symlinks'
pipelines:
tags:
release-*:
- step: *build-generate
- step:
<<: *deploy-to-s3
deployment: 'production'
custom:
deploy-to-staging:
- step:
<<: *deploy-to-s3
I get an error saying
No commands or pipes defined for the step at [pipelines > custom > deploy-to-staging > 1 > step]. Check that you have defined a valid "script" section.
Apparently this is not valid. How should I do this instead?
davina
May 27, 2019
Hi @yivi
You need to move the anchor onto the step i.e.:
  deploy:
- step: &deploy-to-s3
Hope this helps!
yivi
May 27, 2019
Thanks @davina Davina. Now I get
There is an error in your bitbucket-pipelines.yml at [pipelines > custom > deploy-to-staging > 1 > step]. To be precise: This section should be a map (it is currently defined as a list).
The validator says it's fine, although it's not. Would be nice if the validator ran some of the same checks than the actual thing does.
davina
May 28, 2019
I don't get any validation errors after that fix.
image: node:10.15.1
definitions:
build:
script:
- npm install
artifacts:
- dist/**
deploy:
deployment: staging
script:
variables:
ACL: "public-read"
DELETE_FLAG: 'true'
pipelines:
tags:
release-*:
- step:
<<: *deploy-to-s3
custom:
deploy-to-staging:
- step:
<<: *deploy-to-s3
Try copy the whole file with the fix.
