I have a Bitbucket Data Center on a Linux VM in Azure and a remote OpenSearch on a Linux VM in Azure, both are in the same network.
OpenSearch is configured like in: Debian - OpenSearch Documentation
And Bitbucket Data Center is configured like in: Install and configure a remote OpenSearch server | Bitbucket Data Center 8.18 | Atlassian Documentation
When i´m using this on my bitbucket data center vm: "curl -X GET https://IP:9200 -u 'user:pw' --insecure" (with my own credentials, which i setuped), i get the right answer from the opensearch server.
But in Bitbucket i still have connection-result: CONNECTION_ERROR
This is the only thing i can find in the atlassian-bitbucket.log and i doesnt get it:
2024-02-21 14:21:05,499 DEBUG [I/O dispatcher 15] c.a.b.i.s.c.s.t.DefaultSearchConnectionTester Testing connection with search server failed due to exception:
java.util.concurrent.CompletionException: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
And i dont know why.
Does anyone know or have some ideas?
Hi Lasse,
The below error indicates that a target application(in this case OpenSearch) is running with an SSL/TLS configuration but it can't be trusted by Bitbucket. This is most likely due to the peer application's certificate being self-issued (i.e., not signed by a CA) or a certificate chain does not exist within the Java trust store that Bitbucket is using.
I would suggest you review the Unable to connect to SSL services due to "PKIX Path Building Failed" error KB that covers all the possible causes and the fix for this error. In case of any problem, please raise a ticket with Atlassian support.
Aman
Im sorry but this doesnt help me in any way.
Im using self signed certs like the Bitbucket Data Center documentation tells me to do.
But Bitbucket doesnt accept them because their are self signed?
I dont get it.
Hi Lasse,
I will try to clarify all the aspects.
Aman
-Djavax.net.ssl.trustStore
has been configured, it will override the location of the default truststore, which will need to be checked.You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
root@bitbucketVM2:/bitbucket/jre/bin# ./java -Djavax.net.ssl.trustStore=/usr/lib/jvm/java-17-openjdk-amd64/lib/security/cacerts -Djavax.net.debug=ssl SSLPoke 10.28.11.16 9200
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.023 UTC|null:-1|jdk.tls.keyLimits: entry = AES/GCM/NoPadding KeyUpdate 2^37. AES/GCM/NOPADDING:KEYUPDATE = 137438953472
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.071 UTC|null:-1|jdk.tls.keyLimits: entry = ChaCha20-Poly1305 KeyUpdate 2^37. CHACHA20-POLY1305:KEYUPDATE = 137438953472
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.640 UTC|null:-1|KeyLimit read side: algorithm = AES/GCM/NOPADDING:KEYUPDATE
countdown value = 137438953472
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.644 UTC|null:-1|KeyLimit write side: algorithm = AES/GCM/NOPADDING:KEYUPDATE
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.701 UTC|null:-1|KeyLimit read side: algorithm = AES/GCM/NOPADDING:KEYUPDATE
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.703 UTC|null:-1|No X.509 cert selected for EC
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.713 UTC|null:-1|No X.509 cert selected for EC
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.714 UTC|null:-1|No X.509 cert selected for EC
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.714 UTC|null:-1|No X.509 cert selected for EdDSA
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.715 UTC|null:-1|No X.509 cert selected for EdDSA
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.715 UTC|null:-1|No X.509 cert selected for RSA
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.716 UTC|null:-1|No X.509 cert selected for RSA
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.716 UTC|null:-1|No X.509 cert selected for RSASSA-PSS
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.717 UTC|null:-1|No X.509 cert selected for RSASSA-PSS
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.718 UTC|null:-1|No X.509 cert selected for RSA
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.719 UTC|null:-1|No X.509 cert selected for EC
javax.net.ssl|ALL|10|main|2024-02-23 09:06:00.719 UTC|null:-1|No X.509 cert selected for RSA
javax.net.ssl|DEBUG|10|main|2024-02-23 09:06:00.722 UTC|null:-1|KeyLimit write side: algorithm = AES/GCM/NOPADDING:KEYUPDATE
Successfully connected
Im not sure what step helped me to get further, but this is my problem now:
Why does it say it doesnt match the CN, when in CN the correct IP is?
2024-02-23 09:35:42,596 DEBUG [I/O dispatcher 5] c.a.b.i.s.c.s.t.DefaultSearchConnectionTester Testing connection with search server failed due to exception:
java.util.concurrent.CompletionException: javax.net.ssl.SSLPeerUnverifiedException: Host name '10.28.11.16' does not match the certificate subject provided by the peer (CN=10.28.11.16, OU=UNIT, O=ORG, L=TORONTO, ST=ONTARIO, C=CA)
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniApply.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at com.atlassian.elasticsearch.client.apache.httpclient.ApacheRequestExecutor$1.failed(ApacheRequestExecutor.java:160)
at org.apache.http.concurrent.BasicFuture.failed(BasicFuture.java:137)
at org.apache.http.impl.nio.client.DefaultClientExchangeHandlerImpl.executionFailed(DefaultClientExchangeHandlerImpl.java:101)
at org.apache.http.impl.nio.client.AbstractClientExchangeHandler.failed(AbstractClientExchangeHandler.java:432)
at org.apache.http.nio.protocol.HttpAsyncRequestExecutor.exception(HttpAsyncRequestExecutor.java:163)
at org.apache.http.impl.nio.client.InternalIODispatch.onException(InternalIODispatch.java:82)
at org.apache.http.impl.nio.client.InternalIODispatch.onException(InternalIODispatch.java:40)
at org.apache.http.impl.nio.reactor.AbstractIODispatch.outputReady(AbstractIODispatch.java:156)
at org.apache.http.impl.nio.reactor.BaseIOReactor.writable(BaseIOReactor.java:187)
at org.apache.http.impl.nio.reactor.AbstractIOReactor.processEvent(AbstractIOReactor.java:341)
at org.apache.http.impl.nio.reactor.AbstractIOReactor.processEvents(AbstractIOReactor.java:315)
at org.apache.http.impl.nio.reactor.AbstractIOReactor.execute(AbstractIOReactor.java:276)
at org.apache.http.impl.nio.reactor.BaseIOReactor.execute(BaseIOReactor.java:104)
at org.apache.http.impl.nio.reactor.AbstractMultiworkerIOReactor$Worker.run(AbstractMultiworkerIOReactor.java:591)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: javax.net.ssl.SSLPeerUnverifiedException: Host name '10.28.11.16' does not match the certificate subject provided by the peer (CN=10.28.11.16, OU=UNIT, O=ORG, L=TORONTO, ST=ONTARIO, C=CA)
at org.apache.http.nio.conn.ssl.SSLIOSessionStrategy.verifySession(SSLIOSessionStrategy.java:217)
at org.apache.http.nio.conn.ssl.SSLIOSessionStrategy$1.verify(SSLIOSessionStrategy.java:197)
at org.apache.http.nio.reactor.ssl.SSLIOSession.doHandshake(SSLIOSession.java:372)
at org.apache.http.nio.reactor.ssl.SSLIOSession.outboundTransport(SSLIOSession.java:588)
at org.apache.http.impl.nio.reactor.AbstractIODispatch.outputReady(AbstractIODispatch.java:154)
... 7 common frames omitted
