Remote Repository Size Not Reduced After Using git filter-branch
inventiotech
February 24, 2025
I used git filter-branch to reduce the size of two of my repositories. Locally, the size has significantly decreased from approximately 500 MB each to less than 10 MB after running git gc, but the remote repository size on Bitbucket has not changed, even after force-pushing the updated history.
Is there a way for me to run git gc on the remote repository? If not, could someone from the support team please run it for me?
The repositories are:
1. https://bitbucket.org/i*******************s/ph****o
2. https://bitbucket.org/i*******************s/pi*******a
Thank you in advance for your assistance!
Best regards
Patrik S
February 25, 2025
Hey @inventiotech ,
and welcome to the Community!
GC is executed from time to time based on some repository heuristics, but we from support can help expedite its execution.
I went ahead and manually triggered GC for the repositories you have shared, which helped to greatly reduce their size.
Could you check again and let us know if it looks good on your end ?
Thank you, @inventiotech !
Patrik S
inventiotech
February 25, 2025
Hey Patrik,
Everything looks good on my end now. Thank you very much for your help!
Like Patrik S likes this
