Smart commits not working for GitHub
Deleted user September 24, 2012
I successfully linked a GitHub commit to an issue.
I then saw that I could enable smart commits on the GitHub repo linked to the project, so I did that.
I then tested, hoping that the issue would transition, using this commit message:
{code}
SWIM-1 #resolve #time 2d #comment This is a test
{code}
Unfortunately, no dice. Am I doing it wrong? Is this a known limitation with GitHub + JIRA OnDemand?
Abdulrazaq Mohammed Ali Omar
September 26, 2012
Hi Jason,
smart commits will only work correctly if your Email in Git is the same Email in your JIRA user. If the Emails don't match then the smart commits won't work.
All the best
Black Duck
May 17, 2021
Anuj Kumar
July 8, 2014
Even when you have both email address same still smart commits are not working. How can i check the log and find out exact reason for this. I am running an ondemand instance.
Black Duck
May 17, 2021
Did you find your answer. Please help me. I'm facing same problem. My email is same throughout.
Kevin Perard
August 4, 2014
