Stash 2.1 - Project avatars, I apply a project avatar but nothing happens
SA February 5, 2013
I click on the existing project, click on Settings. I upload an image. At this point, the avatar is showing up just inside the preview. As soon as I click save, it goes back to the original and I see no sign of my avatar anywhere.
If I create a new project and upload an avatar then, it works fine. Existing projects' avatars don't change!
Where can I look to find out if there are any error messages or permission issues?
I am running Stash 2.1 on RHEL 6.3 (Santiago)
Jens Schumacher [Atlassian]
February 5, 2013
Try to clear your browser cache. The old avatar might have different caching headers. If that doesn't help, check the log files within the Stash home directory and contact http://support.atlassian.com.
SA February 5, 2013
Silly me, indeed that was the case. I Ctrl+F5d a few times and it finally appeared.
