Two projects/repositories with identical settings - but cannot push commits to one
Balaji Dutt
July 7, 2017
Hi folks,
I have been trying to figure out the source of this fairly odd problem but so far have had no luck.
I'm running Bitbucket Server v4.10.1 and have a few projects configured. Project #1 has the following access permissions
All repositories in the project inherit permissions from the Project.
Output from git when I commit a file to a repository in this project:
$ git clone ssh://git@stash.theaveragegeek.com/servers/server-inv.git
Cloning into 'server-inv'...
remote: Counting objects: 893, done.
remote: Compressing objects: 100% (603/603), done.
Receiving remote: Total 893 (delta 558), reused 468 (delta 288)
Receiving objects: 100% (893/893), 280.22 KiB | 49.00 KiB/s, done.
Resolving deltas: 100% (558/558), done.
Checking connectivity... done.
$ cd server-inv/
$ ls -l > test.txt
$ git add test.txt
$ git commit -m "Test for Community thread"
[master 5a3ed15] Test for Community thread
 1 file changed, 28 insertions(+)
 create mode 100644 test.txt
$ git push -u origin
Counting objects: 3, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (3/3), done.
Writing objects: 100% (3/3), 685 bytes | 0 bytes/s, done.
Total 3 (delta 1), reused 0 (delta 0)
To ssh://git@stash.theaveragegeek.com/servers/server-inv.git
   562d23f..5a3ed15  master -> master
Here are the settings for another project on the same Bitbucket Server instance. As far as I can tell, they are identical to those of the first project linked earlier in my post.
Output from git when I try to commit a file from an existing repository in this project, following the instructions provided in the repository page:
$ cd unixscripts/
$ git remote add origin ssh://git@stash.theaveragegeek.com/scripts/unixscripts.git
$ git push -u origin master
Repository not found
The requested repository does not exist, or you do not have permission to access it.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
I would appreciate any input I can get on why the error is occuring with the second repository.
Balaji Dutt
July 9, 2017
Hi Christian,
That may have been a shot in the dark, but it was a very good one!
Missing access keys was in fact the problem - It seems like I was operating under the impression that when users are granted access via the project permissions, their SSH keys would automatically get carried over, so I did not compare that page between the two projects.
Once I synchronized the access keys between the two projects, I was able to successfully push commits to repositories in the second project.
Christian Glockner
July 7, 2017
Hi Balaji,
This is a shot in the dark, but do you have access keys configured in one repo but not the other?
Christian
Premier Support Engineer
Atlassian
