Unable to create pipeline for Laravel 5.6 project
glazu
March 12, 2018
Hey, I'm trying to create a pipeline for a Laravel 5.6 project, and I am failing miserably.
The issue I get is:
php artisan migrate
In Connection.php line 664:
could not find driver (SQL: select * from information_schema.tables where table_schema = Test and table_name = migrations)
In Connector.php line 67:
and my bitbucket-pipelines.yml is:
image: php:7-fpm
pipelines:
  default:
    - step:
        deployment: test
        script:
          - apt-get update && apt-get install -qy git curl libmcrypt-dev mysql-client zip unzip
          - docker-php-ext-install mcrypt && docker-php-ext-install pdo_mysql
          - ./install-composer.sh
          - composer install
          - export CACHE_DRIVER=redis
          - export SESSION_DRIVER=redis
          - export DB_CONNECTION=mysql
          - php artisan migrate
          - php artisan serve &
          - sleep 5
          - curl -vk http://localhost:8000
        services:
          - mysql
definitions:
  services:
    mysql:
      image: mysql
      environment:
        MYSQL_DATABASE: "Test"
        MYSQL_RANDOM_ROOT_PASSWORD: 'yes'
        MYSQL_USER: "Test"
        MYSQL_PASSWORD: 'Test'
I do not know why this happens, this is my first time creating a pipeline. Any thoughts?
Andrew September 10, 2018
should be
          - export DB_CONNECTION=pdo_mysql
Philip Hodder
April 5, 2018
Hi George,
Looking here (https://stackoverflow.com/questions/22463614/php-artisan-migrate-throwing-pdo-exception-could-not-find-driver-using-larav) it seems you may also need to install php-mysql into your container with apt (I'm not sure on how docker-php-ext-install interacts in this context)
Try adding
apt-get install php-mysql
to your script and see if that helps?
Phil
glazu
March 16, 2018
bump. anyone?
