×Hi,
I would like to try and maybe switch to stash. But I do not want to use JIRA, at least not yet. I have a working setup with redmine that I would like not to change for now.
I use issue numbers in git commits to link them to redmine issues. I believe stash can do the same thing but I would like not to have to sync and duplicate redmine issues to something else.
Can I setup stash to work with redmine and not use Jira?
Thanks.
Hi Anthony,
You can't set up Stash to work with Redmine issues out of the box, but it is possible to write a plugin that provides integration with Redmine.
The JIRA integration in Stash has been implemented as a plugin, so in theory you could write a plugin that replicates that integration for Redmine (and possibly share / sell it on Atlassian Marketplace), but it'll be some work :).
In short, the JIRA integration plugin:
There's a bit more going on behind the scenes, but that's essentially the way the JIRA integration has been implemented. I'd be happy to provide a bit more information if you're interested in implementing such a plugin.
Michael
That's awesome! Exactly the possibility I was hoping for!
I'll look at the code and the language (java I guess), check if I feel comfortable making the changes and definitly get back to you on that.
Thanks!
I am trying to do the same thing with links.
Can you please look at my post and let me know if i am doing anything wrong?
Ram
My question exactly. If you create it as an open source project, do tell :)
Redmine is essentially an issue tracker. Stash is not. So, the general answer is no.
