Heyo,
So just now I updated my pipeline and made the push/merge to the branch (dev). But the pipeline is not running. Could anyone help me out?
Heres the pipeline
image: node:10.15.3
pipelines:
branches:
dev:
- step: name: Build & Deploy PWA
caches: - node
deployment: dev
script:
- cd functions; npm i; cd ..; npm i
- npm run build:prod:pwa
- pipe: atlassian/firebase-deploy:0.3.4
variables:
FIREBASE_TOKEN: '$FIREBASE_TOKEN'
I'm fairly new to this, so any help is gladly appreciated!
This is odd.
If I had to troubleshoot it I would:
Checking Webhooks
Bitbucket will only trigger Pipelines if webhooks are properly set and they should be. They are configured by default but I heard that in some rare cases they were missing, so let's check them up.
Their location: Repository settings >> Workflow - Webhooks.
You should see two of them:
You should be able to enable the onpush one and watch the pushes/merges for the dev branch:
The screenshots above are observed when things are working properly.
I hope one of the checks above can reveal some strangeness that will allow us to move forward in this investigation.
