git push stuck forever when running Bitbucket as a Docker image
davidselin
May 2, 2020
Im running Bitbucket with Atlassians public docker images. Everything seems to be working until I tried to push a little bit bigger git repo. It is like 170 MB,
When i run the command
git push -v
It looks like it uploads all files in the commit but the get stuck on a line forever:
POST git-receive-pack
I have increased the Http.Postbuffer to a really big number.
Regards
/Dave
7 votes
Michael Kimathi _AC Nairobi_ Kenya_
Hello @davidselin
I can understand your frustration as this can be demotivating to your workflow and productivity. We as @ACNairobi we have curated a few suggestions that we think can be of help.
  • Kindly check with your Bitbucket Admin/settings if the file limit is set below 170MB (Increase the size).
  • It would help to also check your internet bandwidth/speed.
  • Cross-check with docker to see if the problem is on the docker side.
Please let me know if any of the above resolutions resolve your problem.
Regards
MK
davidselin
May 2, 2020
Hi @Michael Kimathi _AC Nairobi_ Kenya_
We run Bitbucket as on prem server, is there any limitations on size?
Regarding speed :
  *When I increased the http buffer the push command seemed to run quicker, but it get stuck on POST git-receive-pack.
  * If SSH is used instead, it was back to super slow upload speed.
I have also increased memory on my docker desktop, what else should I check on docker side?
regard
DS
Hello @davidselin ,
Let me know if you followed this guide: https://hub.docker.com/r/atlassian/bitbucket-server/ in setting up the memory and relevant setup (Connection, size, and if you have updated bitbucket server especially if you are running on-prem server) to enable you to run and push without any setbacks.
On ssh please refer here and feel free to raise a support ticket so that Atlassian can replicate your build:
https://jira.atlassian.com/browse/BCLOUD-19451?_ga=2.121742863.568156899.1588359416-1173176553.1588359416
Let me know if it works after following above steps.
Regards
MK
Dave Chevell
May 3, 2020
Hey @davidselin,
A few quick questions:
  1. What version of Bitbucket Server are you running? e.g. 6.10.1, 7.0.1, etc.
  2. How is Bitbucket configured at the HTTP layer? e.g. is it terminating SSL directly? Do you have a reverse proxy in front of it?
I'm wondering whether you cold be running into BSERV-12285 (fixed in 7.1.1 and 7.2.0) but we'd need more information to confirm.
