This might be a bug of pipes in after-scripts on self hosted runners.
I have a step in my bitbucket pipeline as follows:
- step:
name: Build and Test
runs-on:
- self.hosted
- k8s
caches:
- maven
script:
- mvn clean install
after-script:
- pipe: atlassian/checkstyle-report:0.3.1
variables:
DEBUG: "true"
services:
- docker
artifacts:
- target/surefire-reports/**
- target/checkstyle-result.xml
- target/*.jar
`mvn clean install` ran as expected. I could see the jar file, surefire-reports/ and checkstyle-result.xml were generated in "/tmp/8b5a4a4f-f711-583f-95bd-*********/build/target/" directory, I could also see it's mounted to "/opt/atlassian/pipelines/agent/build" within the docker:dind container, but the "checkstyle-report" pipe failed to access "/tmp/8b5a4a4f-f711-583f-95bd-*********/build".
From the `docker container run ***` command, the build seems to be mounted to "/opt/atlassian/pipelines/agent/build" in the checkstyle-report container, but the workdir was set to $(pwd) (i.e. "/tmp/8b5a4a4f-f711-583f-95bd-*********/build") which didn't exist for sure.
Below are the logs of after script:
After script
pipe: atlassian/checkstyle-report:0.3.11m 0s
+ docker container run \--volume=/opt/atlassian/pipelines/agent/build:/opt/atlassian/pipelines/agent/build \
--volume=/usr/local/bin/docker:/usr/local/bin/docker:ro \
--volume=/opt/atlassian/pipelines/agent/ssh:/opt/atlassian/pipelines/agent/ssh:ro \
--volume=/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes:/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes \
--volume=/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes/atlassian/checkstyle-report:/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes/atlassian/checkstyle-report \
--workdir=$(pwd) \
--label=org.bitbucket.pipelines.system=true \
--env=BITBUCKET_STEP_TRIGGERER_UUID="$BITBUCKET_STEP_TRIGGERER_UUID" \
--env=BITBUCKET_REPO_FULL_NAME="$BITBUCKET_REPO_FULL_NAME" \
--env=BITBUCKET_GIT_HTTP_ORIGIN="$BITBUCKET_GIT_HTTP_ORIGIN" \
--env=BITBUCKET_PROJECT_UUID="$BITBUCKET_PROJECT_UUID" \
--env=BITBUCKET_REPO_IS_PRIVATE="$BITBUCKET_REPO_IS_PRIVATE" \
--env=BITBUCKET_WORKSPACE="$BITBUCKET_WORKSPACE" \
--env=BITBUCKET_REPO_OWNER_UUID="$BITBUCKET_REPO_OWNER_UUID" \
--env=BITBUCKET_BRANCH="$BITBUCKET_BRANCH" \
--env=BITBUCKET_REPO_UUID="$BITBUCKET_REPO_UUID" \
--env=BITBUCKET_PROJECT_KEY="$BITBUCKET_PROJECT_KEY" \
--env=BITBUCKET_PARALLEL_STEP_COUNT="$BITBUCKET_PARALLEL_STEP_COUNT" \
--env=BITBUCKET_REPO_SLUG="$BITBUCKET_REPO_SLUG" \
--env=CI="$CI" \
--env=BITBUCKET_REPO_OWNER="$BITBUCKET_REPO_OWNER" \
--env=BITBUCKET_PARALLEL_STEP="$BITBUCKET_PARALLEL_STEP" \
--env=BITBUCKET_STEP_RUN_NUMBER="$BITBUCKET_STEP_RUN_NUMBER" \
--env=BITBUCKET_BUILD_NUMBER="$BITBUCKET_BUILD_NUMBER" \
--env=BITBUCKET_GIT_SSH_ORIGIN="$BITBUCKET_GIT_SSH_ORIGIN" \
--env=BITBUCKET_PIPELINE_UUID="$BITBUCKET_PIPELINE_UUID" \
--env=BITBUCKET_COMMIT="$BITBUCKET_COMMIT" \
--env=PIPELINES_JWT_TOKEN="$PIPELINES_JWT_TOKEN" \
--env=BITBUCKET_STEP_UUID="$BITBUCKET_STEP_UUID" \
--env=BITBUCKET_CLONE_DIR="$BITBUCKET_CLONE_DIR" \
--env=BITBUCKET_DOCKER_HOST_INTERNAL="$BITBUCKET_DOCKER_HOST_INTERNAL" \
--env=DOCKER_HOST="tcp://host.docker.internal:2375" \
--env=BITBUCKET_PIPE_SHARED_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes" \
--env=BITBUCKET_PIPE_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes/atlassian/checkstyle-report" \
--env=CHECKSTYLE_REPORT_ID="checkstyle-1" \
--env=CHECKSTYLE_RESULT_PATTERN=".*/checkstyle-result.xml$" \
--env=DEBUG="true" \
--env=REPORT_FAIL_SEVERITY="info" \
--env=BITBUCKET_EXIT_CODE="$BITBUCKET_EXIT_CODE" \
--add-host="host.docker.internal:$BITBUCKET_DOCKER_HOST_INTERNAL" \
bitbucketpipelines/checkstyle-report:0.3.1
Unable to find image 'bitbucketpipelines/checkstyle-report:0.3.1' locally
0.3.1: Pulling from bitbucketpipelines/checkstyle-report
e7c96db7181b: Pulling fs layer
f910a506b6cb: Pulling fs layer
b6abafe80f63: Pulling fs layer
c66155a2e96a: Pulling fs layer
c66155a2e96a: Waiting
f910a506b6cb: Download complete
e7c96db7181b: Verifying Checksum
e7c96db7181b: Download complete
e7c96db7181b: Pull complete
f910a506b6cb: Pull complete
c66155a2e96a: Verifying Checksum
c66155a2e96a: Download complete
b6abafe80f63: Verifying Checksum
b6abafe80f63: Download complete
b6abafe80f63: Pull complete
c66155a2e96a: Pull complete
Digest: sha256:ce5e8b7e249979ec3fb8e731bc3a26ccaee32e280996dcbaacf1f76eb2924f30
Status: Downloaded newer image for bitbucketpipelines/checkstyle-report:0.3.1
Exception in thread "main" java.lang.RuntimeException: /tmp/8b5a4a4f-f711-583f-95bd-*********/build not found
at se.bjurr.violations.lib.ViolationsApi.inFolder(ViolationsApi.java:45)
at com.atlassian.bitbucket.pipelines.checkstyle.report.Main.main(Main.java:95)
