Test results from gradle multi-module project not showing up in pipelines
LilianaZ December 30, 2017
I'm trying to access my tests results as the build fails in pipelines, but works in three other environments I tested in.
The project is a multi-module gradle project, structured something like this (ommitted all other projects for clarity):
ROOT
| bitbucket-pipelines.yml
| build.gradle
|---> java (level 1)
| build.gradle
|------> data-importer (level 2)
| build.gradle
| (java code for data-importer)
The project is using fairly standard gradle + Spring boot configuration otherwise.
One of the tests in data-importer fails, and the path to the results should be /opt/atlassian/pipelines/agent/build/java/data-importer/build/test-results/test/
According to documentation on: https://confluence.atlassian.com/bitbucket/test-reporting-in-pipelines-939708543.html, the pipelines will look for test results in:
./**/test-results/*.xml
The test report file scanner will begin searching from the base directory of your build: /opt/atlassian/pipelines/agent/build
I believe the problem is either with the path (it is ./**/test-results/*.xml instead of ./**/test-results/test/*.xml), or the fact you only scan 3 directory levels down (not entirely sure how this is counted).
Is there any way I can access the test results other than through pipelines web interface? Alternatively, can you check if there is a problem on your side and the tests path should be amended (or an extra location added) ?
atlassian, mindful member, mindful member badge, atlassian community, community kudos, community giveaway, atlassian swag, community values, empathy and kindness, badge challenge, atlassian learning, community engagement, swag giveaway
Earn a Badge, Win a Prize 🎁
Earning the Mindful Member badge proves you know how to lead with kindness, plus it enters you into a giveaway for exclusive Atlassian swag. Take the quiz, grab the badge, and comment on our announcement article to spread the good vibes!
Start here
