Yes! You can built a full-fledged, end-to-end, scalable product documentation and management solution using Confluence and a couple of apps.
In 30 minutes.
Note: In this article, I only plan to provide the outline of the setup. Time permitting, I’ll deep-dive into the specifics in subsequent articles.
Ready for continuous delivery
Minimal content dependencies
Conditional content (not permission-based)
Single source authoring
Automatic content backups
Edits and Published history
Great SEO
On your own domain(s)
With your own branding
SAML SSO for the internal site
The goal is to have a setup where you have two documentation sites, on your own domain. One site is public, one is for your internal use and features stuff you don’t wanna share. Now, of course you want the internal site behind login - ideally under your corporate SSO. You want to do all your work in a single space to avoid duplication and ensuing chaos.
You’re on a continuous delivery bandwagon and you want to publish the docs updates wherever they’re needed, even several times a day, but at the same time you need to work on drafts and edits, sometimes for weeks.
As some of you know, the above is the setup I deployed at Emplifi. And it was a major factor behind our success. There are alternative setups, one of which, that I tested, is described further down in this piece.
Confluence (you already have that :) )
Two spaces - lets call them Source and Target - no need to enable anonymous access
Comala Document Approval
a simple workflow app that you enable in Source
Comala Publishing
It syncs your finalized Source content to Target - on a page-to-page basis. And it converts the links from Source to Target.
Scroll Documents with Variants
Extends the concept behind what a space is and what a space can do
Handles conditional content - choose which page, section of a page (paragraph, sentence, image) appears in the public site and which is internal only
You create identical setups in Source and Target
Scroll Viewport
Creates a full-fledged documentation portal
Your own domain
Your SSO
Google analytics
Ultimate control over your content and freedom to update your documentation sites independently of whatever’s happening in development - while keeping closely aligned to it via Jira.
At Emplifi, we’re using this very setup for our docs. At any given moment, we can have 50 pages that we work on, enjoying full benefits of Confluence collaboration. At the same time, we can publish ANY page, updated or new, at any point in time pretty much without dependencies.
It saves us a lot of time, we don't fight content conflict battles, and helped us optimize processes behind our docs - writing and the docs life-cycle management.
And can you set up the whole infrastructure it in 30 minutes? Absolutely. I did it several times. With just a couple of clicks.
Yes, you need to know what you're doing and come prepared and synced with your IT/DevOps. But 30 minutes is doable.
Confluence page status (as a workflow app)
Space Sync for Confluence (to sync Source and Target spaces)
Pages Manager for Confluence (free app to manage statuses and syncs)
Note: There are, of course, other apps with more sophisticated approach to workflows and approvals :) And they would greatly expand options of this setup. The ones above are the ones that I tested.
I often fight a lonely Confluence battle in the Write the Docs Slack community, standing between the rock of DIY open source aficionados and the hard place of galactic-scale docs CMS. My point is that you don’t have to scout Stack Overflow to figure out how to code in some rudimentary functionality, nor do you have to pay an arm AND the leg for a tool that has a 1998 GUI and of which you use 20% of the features.
I interact with writers (and others) in the SME segment complaining about the cost of Confluence apps only to go out and buy a $20K a year tool. Case in point, I presented my set of requirements to a major docs CMS vendor. I got a quote for $32,000 - for 4 (as in four) full author seats. I'd still have to pay for webhosting (about $4-5K a year for TWO sites) or built my own solution. And I’d have zero Jira, or any other work management tool, integration.
To compare, my setup costs less than $10K for 50 full seats with Confluence Premium and I'm managing 5 Viewport sites.
I may be preaching to the converted here :) But hey, in the last two months, I helped two writers I met on forums create a version of my setup. And I’m kind of proud of that :)
So I decided to do this write-up and, hopefully, a couple of more detailed followups, as an inspiration and to start a brainstorming discussion.
Kristian Klima
Director of Technical Content, Emplifi
Emplifi
Prague, Czechia
281 accepted answers
4 comments
