I'm getting multiple errors on a Google sheet which I embedded in my Confluence page
Sandeep Nair October 11, 2019
The Google sheet is owned by me and it is in our organization's Gsuite.  When I embed the sheet into the Confluence page, I got multiple errors. Even after logout and login, the error persists.  Thoughts?
Dara
Good luck! Curious to find out what the issue was. Maybe could help others here who have run into similar problems too :).
Sandeep Nair October 15, 2019
Yes, I think the same.
Let me contact our IT guys.
Dara
Are you completely certain that they are doing this in the same way that you are? That is always a good thing to double-check.
If you are performing the exact same actions as your team, but you are the only one receiving these errors, then I think this is an issue of access rights probably. Either to the organisations Gsuite or to Confluence. In any case, an internal IT issue I think.
Sandeep Nair October 14, 2019
BTW, it works for everyone else. The problem occurring at my end only.
I just pasted the URL.
Dara
There seem to be quite a few issues with embedding Google sheets:
https://community.atlassian.com/t5/Confluence-questions/Google-Spreadsheet-embedding/qaq-p/138201
https://community.atlassian.com/t5/Confluence-questions/Embed-Google-Docs-Spreadsheet-in-Confluence-page/qaq-p/271943
Generally, putting it inside the iframe-macro seems to work. How did you embed these sheets?
