Create Jira issue with preassigned component using link does not work
Timo Schütz September 2, 2019 edited
I'm currently setting up a confluence page for our team. We have different pages for different topics and I inserted a overview of the active jira tasks for that topic. I'm currently thinking of using components to filter the issues. I tried to create a link with
https://domain.atlassian.net/secure/CreateIssue.jspa?pid=10014&issuetype=10015&components=10011
but this does not fill in the components, althought the ID is correct.
Where is the issure here?
Thanks for help
4 votes
joey_klein
Solution is to change the url to ……CreateIssueDetails!init.jspa?……
Michal Šípek
That's perfect! It works like a charm. Thanks.
Stan Ry
Hello Timo,
You can do that by using HTML links as described in the following article:
Creating Issues via direct HTML links
If need be, you can add a button as an instance of the UI Button plugin  and then configure the plugin to open the URL configured by using the provided guidelines for creating HTML links. When clicking this button, your users will be present with a typical Create Issue form in Jira where all fields will be configured as filled in URL parameters.
Markup code can look as follows:
<ac:structured-macro ac:macro-id="b33e0b6c-9745-4fdc-84ac-f4ba43349df4" ac:name="ui-button" ac:schema-version="1">
<ac:parameter ac:name="color">blue</ac:parameter>
<ac:parameter ac:name="newWindow">true</ac:parameter>
<ac:parameter ac:name="size">small</ac:parameter>
<ac:parameter ac:name="icon">add</ac:parameter>
<ac:parameter ac:name="tooltip">Click here to create an issue in Jira</ac:parameter>
<ac:parameter ac:name="title">Leave some feedback</ac:parameter>
<ac:parameter ac:name="url">https://example.net/jira/secure/CreateIssueDetails!init.jspa?pid=1234&issuetype=55508&priority=4&summary=User%20Question;labels=Feedback</ac:parameter>
</ac:structured-macro>
Hello Stan,
thanks for the suggestion. I've already found that, but assigning my component does not work. I updated the question above to match my link.
I got the component id from the api endpoint.
Edit: It works with CreateIssueDetails, but then I get the author bug which I cannot solve with user macros, because we are cloud hosted.
Stan Ry
September 2, 2019
Timo, could you please add more on what's the author bug you've mentioned? How it looks like? We are using the approach on the server version and the above code works for me. Let's wait for the guys who have dealt with the cloud version.
Like • Timo Schütz likes this
Timo Schütz September 3, 2019 edited
Hi Stan,
I found that it seems to be an issue with my specific project. On other projects I can create an Incident without the need of adding an author (the field does not appear at all - like I want it to be because all users are logged on). On the specific project it asks me to insert an author, but as I am already logged in it should automatically insert me as the reporter.
Stan Ry
September 4, 2019
Hi again, Timo.
Thanks for the clarification. Have you seen this thread?
Timo Schütz September 4, 2019 edited
Hi Stan,
no I haven't seen this one, but their workaround to be logged in does not work for me. Also I am promted with logging in when I am not, so that did not helped much.
All users which want to use this function are already logged into confluence and I don't want that they need to select themselves as reporter again.
joey_klein
Was there any workaround for the component being defined in the url ? I’m also having this problem
Baris Guner
This is a very late response to this problem but if the Author field mentioned by @Timo Schütz here is a custom field then its custom field id should be used in the link.
From the doco:
"The key and value for custom fields can be found by examining the source code. The name/key are prefixed by 'customfield_' followed by their custom field id. For example: 'customfield_10000' "
For components @joey_klein go to your Project settings -> then choose Components. Once you see a list of them right click on the component you want and Inspect it in Chrome. the ID is revealed as data-component-id tag.
Hope that helps.
