How to add additional row/column to the existing table
Kristina December 14, 2017
How to add additional row/column to the existing table? What is the shortcut for this?
Kris
Post a new question
20 votes
Dan Vitvass
June 20, 2018
adding rows is easy as pie via tabbing; just enter the last row and column and hit the tab key; that will add another row at the end of the table.
- but how can I add columns?
13 votes
Dan Vitvass
June 20, 2018
wow, thanks! I would not have found that function (that icon) without your help! super!
I'm including a screenshot with the tooltip to help others as well
9 votes
Hussain Al-saady
October 7, 2018
If you hover over the buttons mentioned by Nic then they will show you the shortcuts.
Pretty simple:
Alt+Shift+(down arrow)  .... Insert row "After"
Alt+Shift+(up arrow)  .... Insert row "Before"
Alt+Shift+(right arrow)  .... Insert column "After"
Alt+Shift+(left arrow)  .... Insert column "Before"
3 votes
Alissa
September 14, 2023
I do not see the insert row buttons (maybe depreciated from older versions)
But Alt-Ctrl-Arrows worked like a charm!!
3 votes
george
July 27, 2022
I don't see any insert column buttons.  Where do I uncover them?
3 votes
johan.bergstrom
November 26, 2020
It really is a major drawback without this in the iOS app
3 votes
Lin C
September 29, 2019
How about in the app?
3 votes
Nic Brough -Adaptavist-
December 14, 2017
Click on the "insert row beneath" button on the toolbar, after putting the cursor on the right line.  There's no keyboard shortcut for this though.
Jan Hegr
February 22, 2023
Thank you for the tip with the tab key on the very last cell. However, mentioned shortcuts Alt-Shift-Arrow don't work for me and I need to insert a row in the middle of the table. I cannot locate the toolbar buttons for these actions, they're probably not (much) accessible for screen-readers. I'm blind so screenshot posted here also don't help.
Please, do you have any hint how to achieve this using a keyboard?
Edit: With sighted assistance we discovered the shortcuts Alt-Ctrl-Arrows, which work for me. Thanks.
kurt
October 25, 2022
How do you get that Responsive icon bar to show up, in order to have the icons for adding columns?
Alexander Schiftner November 7, 2020
Hmm, running into the same issue, is it impossible to add further rows using the ios app?
Piotr Zolnierek
Same for ios... a year later, still unusable without that feature
Nenad Đuričić
November 21, 2019
I didn't find how to add row in Android app
Dinen Surchowdhury
September 18, 2023
Merge cells is the answer I think you are trying to find.
Nix Blay
March 13, 2023
fab! Its been driving me nuts trying to work this out as never had to created any tables and needed to edit an existing one - I don't have any of those icons people were referring to either but this shortcut worked - :D  Thankyou!
Eric Tong
November 1, 2022
I having issue on adding new row. the problem is on one particular row, it has multiple sub rows starts from the second column. Now when I add a new row, the new row is start from the second column as a new sub-row, however I do want to just add a new row which should start from the first column.
Ales Kerry
May 4, 2021
amazing, much obliged! I would not have discovered that work (that symbol) without your assistance! super!
I'm incorporating a screen capture with the tooltip to help other people also
Jason Smith February 15, 2021
Why oh whhhhhhyyyy can they not bring it in already, surely the devs are all over this type of ish! :-/
Helpful, Nic. Thanks for the insight.
February 13, 2021
It's not an add-on, it's the way it worked four years ago.  And on a different platform.
Paul Ericson
February 12, 2021
Still not in the iOS app AFAIK.
Jason Smith November 11, 2020
Are these options from an add-on? Without this add-on can one split cells i.e. add columns and/or rows within without add actual rows and columns to the whole table?
Johnny Jiron
February 4, 2020
Thanks @Dan Vitvass , for some reason the buttons were not working, but the tab works just fine!
Deleted user October 8, 2019
thank you for this helpful tip!
Christina Gheorghe May 21, 2019
Yes thank you! Big help in finding the right buttons.
Post a new question
