When migrating to Confluence 4.0, we are experiencing issues with Activity Streams not displaying issues from spaces correctly. We have tested other methods (user specific filtering, update date) and they are correctly displaying activity, however when we try to apply the global filter of certain spaces, we only see information from when the space was created (sometimes as much as a year ago, with no activity since then, when there has definitely been activity), nothing current.
I'm not sure if this is relevant, but several of the spaces have several (3-8) components to which all issues are tied. This had no negative effect on issue reporting in the Activity Stream before migrating, so I doubt it would be the cause.
Hi Nark,
I'm not too sure what's going on here, the only thing I can think of is that you may need to perform a reindex. It's worth logging a ticket through to http://support.atlassian.com and requesting an engineer look into this issue, and potentally reindex your instance. The problems seem to be too specific for us to be able to solve without investigating the specific goings on in your intance.
Matt
Sorry it has taken so long to respond!
It looks like the original issue where we were seeing nothing due to the "Spaces" filter has seemed to resolve itself (go figure), however this has opened up a new issue.
From doing a little more research, it looks like our instance does not have the "Project" filter as a global filter to use; we have Space, JIRA Issue Key, Update Date and Username. No idea what could be causing this, could it be something set at the admin level?
Is this Confluence, or JIRA?
