Add a caption feature does not work in Edge browser
정대규
December 12, 2024
The add a caption feature works fine in Chrome browser, but in Edge browser, I can't enter content even when I double-click. What settings should I change?
4 votes
Ruth Schneider
Here is a workaround that works for me until Atlassian fixes the bug:
In edit mode click on the picture for which you want to add a caption
Press the tab key
Enter the caption
Press Enter
I hope this helps :)
You might want to vote for the bug in the meantime:
[CONFCLOUD-80384] Image description is not working as expected in Edge browser. - Create and track feature requests for Atlassian products.
Ellen Niles January 8, 2025
Thanks!
That workaround worked for me and once it exists as a caption, I can just click into it, don't have to use the tab key again :)
Voted on the bug.
Appreciate it!
Like Ruth Schneider likes this
3 votes
Ellen Niles December 13, 2024
Same issue here, updated browser, still experiencing.
Version 131.0.2903.99
Not able to click the caption, goes to next line
Ellen Niles July 21, 2025
Using browser version 138.0.3351.83 (Official build) (64-bit) this is resolved for me.
One click I can enter into the caption under the image and type an entry.
Double clicking shows a preview of the image, but not a preview of the caption/image with caption.
3 votes
Pete Bath
December 13, 2024
Having the same issue in edge. Click the add caption and it just goes to the next line. Must be a bug.
Manuel Negru December 17, 2024
+1 We are experiencing the same issue. Chrome is working fine.
Tim Jacobs
January 7, 2025
We are experiencing the same issue. I have just reopened the case with Atlassian.
Ruth Schneider
Same issue here, Edge Version 131.0.2903.112
