The add a caption feature works fine in Chrome browser, but in Edge browser, I can't enter content even when I double-click. What settings should I change?
Here is a workaround that works for me until Atlassian fixes the bug:
In edit mode click on the picture for which you want to add a caption
Press the tab key
Enter the caption
Press Enter
I hope this helps :)
You might want to vote for the bug in the meantime:
Thanks!
That workaround worked for me and once it exists as a caption, I can just click into it, don't have to use the tab key again :)
Voted on the bug.
Appreciate it!
Same issue here, updated browser, still experiencing.
Version 131.0.2903.99
Not able to click the caption, goes to next line
Using browser version 138.0.3351.83 (Official build) (64-bit) this is resolved for me.
One click I can enter into the caption under the image and type an entry.
Double clicking shows a preview of the image, but not a preview of the caption/image with caption.
Having the same issue in edge. Click the add caption and it just goes to the next line. Must be a bug.
+1 We are experiencing the same issue. Chrome is working fine.
We are experiencing the same issue. I have just reopened the case with Atlassian.
Same issue here, Edge Version 131.0.2903.112
