×Hi,
We have JIRA and Conflucne. I understand the JIRA issue collectors can't use 'user picker' feilds.
Can 'user picker' feilds be used, using the advanced use guide it seem to look like it can?
If so does any one have example code?
Many Thanks
Kevin
I never heard that an user picker can be used on a Jira Issue Collector form..
This is what documentation is saying
Not all fields of types of fields can be added to the form, since some fields cannot be displayed to anonymous users. The fields types that can be displayed are:
Standard Fields: Summary, Description, Components, AffectsVersion, Environment, Priority, Attachment
Custom Field Types: Date Time, Radio Buttons, Multi-Checkbox, Multi-Select, Number, Select List, URL field, Version Picker, Cascading Select, Project Picker, Single Version Picker, Text Field, Free Text Field
https://confluence.atlassian.com/adminjiraserver/using-the-issue-collector-938847338.html
So no User Picker
