Code macro does not maintain line breaks or code indentations in Safari
Dave Carlton April 8, 2019
Type {code
Select Code Block
Paste in
case HID_POV:
    if(sval >= _StickElements[i].ref->min && sval <=  _StickElements[i].ref->max)
It becomes:
case HID_POV:
Extra lines are added, indentation is gone
Found part of the problem, copying code from Xcode the clipboard is in RTF. If I first paste into Aquamacs, then copy that text it is now plain text which can then be pasted into confluence retaining the lines and indentation.
