I have filtered epics of quite a few different projects into an advanced roadmap view to create a portfolio overview. When I tried to colour by project, I am not getting different colours but the same for most of the project, which is not very useful. Is there are limit on how many projects can be filtered into one view or why would colouring by project not work?
Thank you
Hi @Anitha Jeyanthan ,
If you use our Table Filter and Charts for Confluence app and its Chart from Table macro in your company, we can suggest trying the Gantt Chart instead of the Advanced Roadmap plan.
Our chart is a customized one and allows you to use a standard color panel and define your own HEX code colors using the Colors in the table columns option. Please check here for more info.
How to built a chart using the Jira Issues macro - please look here.
The only difference for you as a Cloud user will be that you'll need to nest macros via the Table Toolbox, other steps will be the same.
Hi there,
As this thread concerns our Table Filter and Charts for Confluence app, we are happy to announce its new macro – Table Spreadsheet.
This new macro allows you to work with fully functional Excel spreadsheets right in Confluence.
You’ll be able to use filters, cells’ formulas, conditional formatting, etc., create pivot (aggregated) tables and charts from the page view&edit mode.
The Table Spreadsheet macro works for Cloud and Server/Data Center.
