ConfiForms: problem with IFTTT Create ConfiForms Entry
Bartosz Drożdżal
Hi @Alex Medved _ConfiForms_
I have a problem with ifttt create confiforms entry which is triggered in several forms one after another.
I have the configuration as in the attached screenshot, but the ifttt create confiforms entry from the test1 form doesn't work. Other ifttts, such as create page or create comment, work correctly.
You need to set the IFTTT to execute all the IFTTT rules, by default it does not invoke create/update IFTTTs to protect from possible infinite loops (which it will still detect) - it is an option the IFTTT macro (create/update confiforms entry)
Bartosz Drożdżal
Great, thank you so much for the explanation!
However, I noticed that after checking this option, ifttt update confiforms entries by filter still doesn't work. Is there anything I can do about this?
Does it have a condition to run? Is it present or not in the invocation log on the screen (after enabling. the debug mode)?
SERVER
