Hi There
I've installed an evaluation license for CLI. In a Confluence page, I've tried to launch a simple CLI command, to get the Space permission list and set the result in a CSV file.
So, in the body of the CLI macro, I set:
-a getSpacePermissionList --file junk.csv
Options: product=confluence; showCommand=true; server=myServer; subDirectory=.; user=raltmaye; password=myPassword
result: an exception:
Unable to log in to server: https://atlassian-dev.hq.k.grp/confluence/rpc/soap-axis/confluenceservice-v1 with user: raltmaye. Cause: ; nested exception is: com.atlassian.crowd.exception.runtime.OperationFailedException
Oops - I gave you the wrong path to the log - it is in your <confluence home>/logs directory!
Don't worry Ann, I know where logs are :)
So, in my log, I can see a strange error message:
{noformat}
2013-09-17 20:23:33,359 ERROR [http-localhost%2F127.0.0.1-8090-11] [crowd.manager.application.ApplicationServiceGeneric] authenticateUser Directory 'Crowd Server TEST' is not functional during authentication of 'raltmaye'. Skipped.
-- url: /confluence/rpc/soap-axis/confluenceservice-v1 | userName: anonymous
2013-09-17 20:23:33,364 ERROR [http-localhost%2F127.0.0.1-8090-11] [ContainerBase.[Catalina].[localhost].[/confluence]] log Unhandled exception occurred whilst decorating page
{noformat}
Strange, for my Crowd server is perfectly running (Confluence authentication is done against it, without any issue); the Users Directory is synchronized without any issue, and I can log on Confluence
Regis
See if it is reproducable running the action directly from a command line. Not sure what that will mean, but, it would make it an easier reproduce scenario.
Hi Bob
You were sure to suggest such a thing :) I had tried it too. The result is consistent, I get the same error message, whatever command I try:
ccli -u raltmaye -p $pwd -a getServerInfo -s https://atlassian-dev.hq.k.grp/confluence
Cause: com.atlassian.crowd.exception.runtime.OperationFailedException
I've of course checked the remote APIs were enabled on this test server.
Regis
Ok, expected that, so, that simplifies the failure. Since it is a server failure, I think it is most likely reproducible with any soap remote API access and that is something that Atlassian support should be able to work on.
We tried this locally using SSL and the CLI tool and it worked. Unfortunately the error in the GUI is pretty generic. You will want to find the fulll error in your atlassian-confluence.log file in the <confluence install>/logs directory and research that error.
