×I have Confluence 4.1 and Crowd 2.3.3 in my environment and was trying to get SSO to work. I followed everything in the documentation and SSO worked. But when I login to Confluence, part of the system no longer work. And i am puzzled what the heck is going on.
Have anyone faced this problem before?
Confluence SSO config is correct or else i can't login, isn't it? Hmm...
Confluence Log:
2012-02-09 23:38:38,293 ERROR [http-80-8] [atlassian.confluence.servlet.ConfluenceServletDispatcher] serviceAction There is no Action mapped for namespace /status and action name update
-- referer: http://confluence.test.com/dashboard.action | url: /status/update.action | userName: tester
Handled by support.
Doesn't look like and issue with SSO. Did you see it only after enabling SSO? What is the language you have in your profile now? Seems internationalization is broken somehow!
Yes, this happens after enabling SSO. I'll probably file for a support request to ask what's going on. Thanks mate.
Handled by support.
