Confluence Database - Jira issue Field and Jira Issue Details doesnt work
Fazal Shaik January 21, 2025
Basically I dont see any options coming up in Jira Instance drop down. Does the site admin have to configure this?
We are not on jira cloud but we do use Confluence Cloud. So please help confirm if this is only available for jira cloud instances?
Barbara Szczesniak
January 21, 2025
@Fazal Shaik Has your Admin connected your Jira Server instance with your Confluence Cloud instance? I think you need to do this first before you can select it in the Jira Instance field. See this page for information: https://confluence.atlassian.com/enterprise/integrate-confluence-cloud-with-jira-server-1101925671.html
Fazal Shaik January 22, 2025
@Barbara Szczesniak Thank you for the response. I looked at the article and I already see we are able to link tickets to confluence. And also able to display issues on a page. Does that confirm that jira server instance is connected to confluence cloud instance? Or we need to do something else as well to see the instance showing up in database.
Barbara Szczesniak
January 22, 2025
@Fazal Shaik I have not used this feature, so I can't be sure why your Jira instance doesn't populate in the dropdown list. Is this a field that you can also type text into? If so, you can try typing some text that is in the name of the Jira instance. This would prompt the application to offer the instance as a choice for you to select.
No its not a text field. Just a drop down with nothing in it.
Barbara Szczesniak
January 22, 2025
@Fazal Shaik We've reached the limit of my knowledge on this subject. Perhaps you can find something helpful in the responses to this post: https://community.atlassian.com/t5/Jira-questions/Broken-link-between-Jira-Server-and-Confluence-Cloud/qaq-p/2364825
Like Fazal Shaik likes this
Appreciate your responses. Will take a look
Fazal Shaik January 23, 2025
I am told by our admin that those features are only if we have jira cloud and not for jira data center. Can someone in Atlassian help confirm?
@Christina Ristevski Could you please help confirm if jira instance will only show up if we have jira cloud and not for jira data center? This is stopping us from adopting this in our org.
Ajay _view26_
Hi @Fazal Shaik
Can you provide more context as the title "Confluence Database" is creating confusion..
What I meant by was while creating a database in confluence and adding Jira Issue field.
