Confluence and Jira on same machine
Anurag Ashok October 5, 2017
I am not getting success to install the Jira and Confluence in same machine. Jira is already working but when I tried to install confluence, Jira also stopped working.
I followed the confluence installation as mentioned in document and able to reach upto url http://localhost:8090. But unable to connect with any one of options: standard JDBC database connection or Datasource Name.
Can you provide simple step by step procedure for installing confluence with existing Jira machine.
Gonchik Tsymzhitov
Hi!
Please, see below:
https://confluence.atlassian.com/conf57/installing-confluence-and-jira-together-701435562.html
https://community.atlassian.com/t5/Jira-questions/Installing-JIRA-and-Confluence-on-the-same-server/qaq-p/6105
Step by step:
1. mkdir /atlassian
2. extract tar file /atlassian/confluence
3. extract tar file /atlassian/jira
4. set split home directories like this /atlassian/confluence-home
5. set split home directories like this /atlassian/jira-home
6. set java home
7. and configure conf/server.xml for different port jira and confluence
8. After that you configure systemd or init.d file
9. start system
I hope this info enough.
