Confluence as Knowledge-System for Call Center?
Arnd R. Walendy
October 8, 2015
Does somebody know a Company  using Confluence as Knowledge-System for his Call Center?
The point is not what we wanna do or what we would like. The point is, that some of our internal customers like to know, wether Confluence is used by others as call-center-solution or not ;-)
Giuliano C_
October 8, 2015
You might want to choose one of the options for a Call center:
https://confluence.atlassian.com/doc/confluence-use-cases-283641068.html
However, if you want to implement it for specific purposes, can you let us know a bit more on how you want ot use it? smile
Giu
Nic Brough -Adaptavist-
October 8, 2015
I was going to say that I know of several places using Confluence for call-centre related stuff. As Giuliano says though, their exact usage may not be what you need, so it would be better for you to describe what *you* would like from it and see what we can help you with!
Guilherme V.
October 8, 2015
You can check the current Atlassian's customers in the following link:
https://www.atlassian.com/customers/?page=3&sortParam=date_created%20desc&productsUsed=Confluence
Arnd R. Walendy
October 11, 2015
thnx
