Hello, confluence suddenly stopped working and there is an error like this:
Could not load bootstrap from environment
2020-08-12 17:29:16 fatal IllegalStateException: File corrupted in chunk 3218287, expected page length 4..192, got 0 [1.4.196/6]
I ask for your help, thanks
Hello Eugene,
Let's see how we can get you back up and running on Confluence.
Could you let me know about the database that you're using with Confluence? What type of database is it, and what's the version?
Please also confirm with me your Confluence version, and if you've upgraded recently.
Thank you!
Shannon
I did it as indicated in the article, unfortunately this did not solve my problem, can I do something else? I would be very grateful for any help
Hello @Eugene Filippovsky ,
Have you had a chance to look at the other posts, where users were having similar issue. There is an answer on below posts if you like to check it out and see if that helps you
- https://community.atlassian.com/t5/Confluence-questions/Could-not-load-bootstrap-from-environment-BootstrapException/qaq-p/990186
- https://community.atlassian.com/t5/Confluence-questions/Could-not-load-bootstrap-from-environment/qaq-p/768846
