×Hi @551550,
it seems that you have an error on line one of your config file, so you should check, if there is something wrong.
It is probably the confluence.cfg.xml file in your Home-Folder.
Please follow this to generate a new file.
https://confluence.atlassian.com/confkb/how-to-generate-a-new-confluence-cfg-xml-425461512.html
