Confluence not working in Edge
Jared Fernley
September 9, 2019
When trying to open a Confluence space in Edge it goes to a blank page with the Confluence logo and the site will not come up. It works just fine in Chrome or IE but our staffs administratively set default browser is Edge. Any known fix for this issue? Here is a screenshot of the image seen in Edge:
Xiao Lei
September 1, 2020
Same here. No way to resolve? I can steady reproduce it on 10+ machines running Edge.
Louise Cranfield November 13, 2019
Same issue here, for me, using Edge 42.17134.1.0, but also for my client, who is using totally separate network and OS.
oezguer.cirakoglu
October 18, 2019
same issue, I am also using Edge browser and can't open confluence. I have also tried the InPrivate mode, but same behavior.
Confluence Version: 1000.0.0-75685dacf2e
Edge Version: 42.17134.1.0
Here is the Edge browser listed as supported browser: https://confluence.atlassian.com/conf615/supported-platforms-967338803.html?_ga=2.128456780.1716430037.1571390445-1812912414.1571390445
Kiran Panduga {Appfire}
Hi @Jared Fernley ,
Edge is not a supported browser for Confluence. Please refer to the below Link to list the Supported Browsers for Confluence latest version 6.15.x
Kiran.
Michael Lykke
September 10, 2019
I have the same issue - works fine in all other browsers. (but I need to use edge for this pc)
Kiran, Edge IS listed as a supported browser on that link.
things tried:
- sfc /scannow
- reset edge
-repair edge
- clear all edge browsercache
Any info on a fix for this ?
Hi @Michael Lykke ,
Yes, Edge IS supports for Confluence v6.15. Not sure of the Confluence version @Jared Fernley  is using.
If supported, then the best troubleshooting is to clean up the cookies, cache which you already performed.
Try using the InPrivate in Edge and verify.
https://support.microsoft.com/en-in/help/4026200/microsoft-edge-browse-inprivate
Also, if your confluence server using multiple third-party add-ons then it is possible some styling applied might not yet be supported on all browsers.
Enabling safe mode will disable all add-ons. Check again to see if it is working. https://confluence.atlassian.com/upm/disabling-and-enabling-add-ons-273875716.html
Kiran.
Michael Lykke
September 10, 2019
For your info.
EDGE not working with confluence - infinite loading screen.
Microsoft Edge 42.17134.1.0
Microsoft EdgeHTML 17.17134
Edge version working. (Run windows 10 update 1903 and it will fix this)
Microsoft Edge 44.17763.1.0
Microsoft EdgeHTML 18.17763
Like # people like this
