Confluence system property macro.required.velocity.context.keys not set
Jurica Petricevic
September 5, 2023
Hi Community,
after the update to 7.19.11 we have a problem with macro commands. How to add the necessary properties to the system or does this not work at all?
Error:
User Macro show-content-group may use context keys [ userAccessor, action, req ] which are not set in system property macro.required.velocity.context.keys. If the macro is not rendered as expected, try to manually add those keys into the system property.
3 votes
Jurica Petricevic
September 5, 2023
Properties addad like this and problem is solved.
CATALINA_OPTS="-Dmacro.required.velocity.context.keys=comma,seperated,key,values,userAccessor,permissionHelper,action,pageManager,req"
in:
/opt/atlassian/confluence/bin/setenv.sh
Jurica Petricevic
September 5, 2023
This burdened our system to such an extent that normal operation was no longer possible. This is not a solution for us. We are looking for other solutions.
Like # people like this
Kseniia Trushnikova
Hi @Jurica Petricevic,
In your case, adding just this is enough:
CATALINA_OPTS="$CATALINA_OPTS -Dmacro.required.velocity.context.keys=userAccessor,action,req"
Please check out the bug ticket https://jira.atlassian.com/browse/CONFSERVER-82741 related to your issue, there's a note from Atlassian. The behaviour you're experiencing is intended.
SERVER
VERSION
7.19.11
