×Hi,
We are trying to connect Confluence server with Microsoft AD using SSL. But we keep getting this error message.
nested exception is javax.naming.CommunicationException
Root exception is javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No name matching
How can i fix this ?
Dear @Dominik Žarković,
most probably your SSL certificate is not trusted by the JVM. To fix this you can do following:
-Djavax.net.ssl.trustStore=/path/to/keystore
java/jre/lib/security/cacerts
So long
Thomas
