×Confluence connection is not possible.
I will share your SEN number with you, so please check it.
Why is access denied?
If the deadline has expired, I would like to reconnect. Please check which cloud it is connected to.
SEN-48695060
Hi @양연경 ,
Welcome to the community !!
There is no active incidents in Atlassian cloud (https://status.atlassian.com/).
Is the error displayed only for you or for all users in your organization ?
If its only for you, try accessing the url in different browser OR access url incognito mode OR try restarting your laptop.
If the issue is for all users, please raise ticket with Atlassian Support in https://support.atlassian.com/contact/
